Date/Time: Mon, 23 Dec 2024 06:49:46 +0000
Called sc.ExponentialMovAvg() but based on slope
View Count: 1446
[2015-09-21 15:10:33] |
CMG - Posts: 179 |
Hello, I need to call the sc.ExponentialMovAvg() but based on slope, I have not been able to find the parameter or a code example, could you help me with this please. Thanks in advanced. PV |
[2015-09-21 18:26:47] |
We are not totally sure what is meant by "based on slope".
[2015-09-21 18:50:12] |
CMG - Posts: 179 |
It is the autocoloring option based on slope for the subgraph. http://screencast.com/t/KnIx6IEBef Tks |
[2015-09-21 18:54:47] |
CMG - Posts: 179 |
I think is this one: sc.Subgraph[1].AutoColoring = AUTOCOLOR_SLOPE; thanks |
[2015-09-21 19:46:35] |
Yes, that is correct. You can set Auto Coloring on a sc.Subgraph[]. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_scSubgraph.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-21 19:46:45
