Date/Time: Mon, 23 Dec 2024 06:39:45 +0000
It always show "Waiting to reconnect...."
View Count: 1160
[2015-09-21 13:28:14]
User138619 - Posts: 3
Software version: 1297 | 2015-09-21 13:18:33
Uses New Spreadsheets | 2015-09-21 13:18:33
Usage end date: 2015-10-04 | 2015-09-21 13:18:33
Enabled for: Advanced Features. | 2015-09-21 13:18:33
Enabled for: Advanced Features 2. | 2015-09-21 13:18:33
Enabled for: Sierra Chart Historical Data Service. | 2015-09-21 13:18:33
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-09-21 13:18:33
Current selected Data/Trading service: Rithmic Trading | 2015-09-21 13:18:33
Chart Update Interval: 900 | 2015-09-21 13:18:33
Time Zone: +00:00:00 (UTC+00) | 2015-09-21 13:18:33
2015-09-21 21:18:33 Local computer time | 2015-09-21 13:18:33
2015-09-21 13:18:33 Local computer time in UTC | 2015-09-21 13:18:33
2015-09-21 13:18:33 Local computer time in SC Time Zone | 2015-09-21 13:18:33
2015-09-21 13:18:33 Server time in UTC | 2015-09-21 13:18:33
Local computer UTC time and Server UTC time difference: 5 seconds. | 2015-09-21 13:18:33
Program path: C:\SierraChart\ | 2015-09-21 13:18:33
Data Files path: C:\SierraChart\Data\ | 2015-09-21 13:18:33
OS Version Number: 6.2 | 2015-09-21 13:18:33
Locale Information: C | 2015-09-21 13:18:33
Checking for new symbol settings for rim | 2015-09-21 13:18:33
Symbol settings are up-to-date for rim | 2015-09-21 13:18:34
Rithmic Trading | Port for executable: 52539 | 2015-09-21 13:18:38
Listening socket (1048), port 52539 | Closed. | 2015-09-21 13:18:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-09-21 13:18:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52539 | 2015-09-21 13:18:40
Socket (4) | Connected. | 2015-09-21 13:18:40
Rithmic Trading | Connected to server. | 2015-09-21 13:18:40
Rithmic Trading | Sending logon request message. | 2015-09-21 13:18:40
Rithmic Trading | Starting the connection process to data and trading service. | 2015-09-21 13:18:40
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-09-21 13:18:40
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-09-21 13:18:40
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-09-21 13:18:42
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-09-21 13:18:43
Rithmic Trading | Server Name: DTC Bridge. | 2015-09-21 13:18:43
Rithmic Trading | Server protocol version: 7. Client protocol version: 7. There is a protocol match. | 2015-09-21 13:18:43
Rithmic Trading | Logon error from server | 2015-09-21 13:18:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:18:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:18:43
Socket (4) | Shutdown and closed. | 2015-09-21 13:18:43
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:18:43
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:18:43
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:18:45
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52539 | 2015-09-21 13:18:47
Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:18:48
Socket (5) | Shutdown and closed. | 2015-09-21 13:18:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:18:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:18:48
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:18:48
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:18:48
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:18:50
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52539 | 2015-09-21 13:18:52
Socket (6) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:18:53
Socket (6) | Shutdown and closed. | 2015-09-21 13:18:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:18:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:18:53
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:18:53
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:18:53
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:18:55
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52539 | 2015-09-21 13:18:57
Socket (7) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:18:58
Socket (7) | Shutdown and closed. | 2015-09-21 13:18:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:18:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:18:58
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:18:58
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:18:58
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:19:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52539 | 2015-09-21 13:19:02
Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:19:03
Socket (8) | Shutdown and closed. | 2015-09-21 13:19:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:19:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:19:03
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:19:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:19:03
Current selected Data/Trading service: Rithmic Trading | 2015-09-21 13:19:03
Rithmic Trading | Port for executable: 52568 | 2015-09-21 13:19:05
Listening socket (964), port 52568 | Closed. | 2015-09-21 13:19:05
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-09-21 13:19:05
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52568 | 2015-09-21 13:19:07
Socket (9) | Connected. | 2015-09-21 13:19:07
Rithmic Trading | Connected to server. | 2015-09-21 13:19:07
Rithmic Trading | Sending logon request message. | 2015-09-21 13:19:07
Rithmic Trading | Starting the connection process to data and trading service. | 2015-09-21 13:19:07
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-09-21 13:19:07
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-09-21 13:19:07
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-09-21 13:19:09
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-09-21 13:19:10
Rithmic Trading | Server Name: DTC Bridge. | 2015-09-21 13:19:10
Rithmic Trading | Server protocol version: 7. Client protocol version: 7. There is a protocol match. | 2015-09-21 13:19:10
Rithmic Trading | Logon error from server | 2015-09-21 13:19:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:19:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:19:10
Socket (9) | Shutdown and closed. | 2015-09-21 13:19:10
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:19:10
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:19:10
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:19:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52568 | 2015-09-21 13:19:14
Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:19:15
Socket (10) | Shutdown and closed. | 2015-09-21 13:19:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:19:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:19:15
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:19:15
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:19:15
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:19:17
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52568 | 2015-09-21 13:19:19
Socket (11) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:19:20
Socket (11) | Shutdown and closed. | 2015-09-21 13:19:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:19:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:19:20
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:19:20
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:19:20
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:19:22
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52568 | 2015-09-21 13:19:24
Socket (12) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:19:25
Socket (12) | Shutdown and closed. | 2015-09-21 13:19:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:19:25
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:19:25
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:19:25
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:19:25
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:19:27
Current selected Data/Trading service: Rithmic Trading | 2015-09-21 13:19:27
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52568 | 2015-09-21 13:19:29
Socket (13) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:19:30
Socket (13) | Shutdown and closed. | 2015-09-21 13:19:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:19:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:19:30
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:19:30
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:19:30
Rithmic Trading | Port for executable: 52591 | 2015-09-21 13:19:32
Listening socket (1064), port 52591 | Closed. | 2015-09-21 13:19:32
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-09-21 13:19:32
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52591 | 2015-09-21 13:19:34
Socket (14) | Connected. | 2015-09-21 13:19:34
Rithmic Trading | Connected to server. | 2015-09-21 13:19:34
Rithmic Trading | Sending logon request message. | 2015-09-21 13:19:34
Rithmic Trading | Starting the connection process to data and trading service. | 2015-09-21 13:19:34
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-09-21 13:19:34
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-09-21 13:19:34
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-09-21 13:19:36
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-09-21 13:19:37
Rithmic Trading | Server Name: DTC Bridge. | 2015-09-21 13:19:37
Rithmic Trading | Server protocol version: 7. Client protocol version: 7. There is a protocol match. | 2015-09-21 13:19:37
Rithmic Trading | Logon error from server | 2015-09-21 13:19:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:19:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:19:37
Socket (14) | Shutdown and closed. | 2015-09-21 13:19:37
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:19:37
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:19:37
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:19:39
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52591 | 2015-09-21 13:19:41
Socket (15) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:19:42
Socket (15) | Shutdown and closed. | 2015-09-21 13:19:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:19:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:19:42
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:19:42
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:19:42
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:19:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52591 | 2015-09-21 13:19:46
Socket (16) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:19:47
Socket (16) | Shutdown and closed. | 2015-09-21 13:19:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:19:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:19:47
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:19:47
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:19:47
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:19:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52591 | 2015-09-21 13:19:51
Socket (17) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:19:52
Socket (17) | Shutdown and closed. | 2015-09-21 13:19:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:19:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:19:52
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:19:52
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:19:52
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:19:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52591 | 2015-09-21 13:19:56
Socket (18) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:19:57
Socket (18) | Shutdown and closed. | 2015-09-21 13:19:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:19:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:19:57
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:19:57
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:19:57
Rithmic Trading | Port for executable: 52614 | 2015-09-21 13:19:59
Listening socket (932), port 52614 | Closed. | 2015-09-21 13:19:59
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-09-21 13:19:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52614 | 2015-09-21 13:20:01
Socket (19) | Connected. | 2015-09-21 13:20:01
Rithmic Trading | Connected to server. | 2015-09-21 13:20:01
Rithmic Trading | Sending logon request message. | 2015-09-21 13:20:01
Rithmic Trading | Starting the connection process to data and trading service. | 2015-09-21 13:20:01
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-09-21 13:20:01
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-09-21 13:20:01
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-09-21 13:20:04
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-09-21 13:20:04
Rithmic Trading | Server Name: DTC Bridge. | 2015-09-21 13:20:04
Rithmic Trading | Server protocol version: 7. Client protocol version: 7. There is a protocol match. | 2015-09-21 13:20:04
Rithmic Trading | Logon error from server | 2015-09-21 13:20:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:20:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:20:04
Socket (19) | Shutdown and closed. | 2015-09-21 13:20:04
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:20:04
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:20:04
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:20:06
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52614 | 2015-09-21 13:20:08
Socket (20) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:20:09
Socket (20) | Shutdown and closed. | 2015-09-21 13:20:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:20:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:20:09
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:20:09
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:20:09
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:20:11
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52614 | 2015-09-21 13:20:13
Socket (21) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:20:14
Socket (21) | Shutdown and closed. | 2015-09-21 13:20:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:20:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:20:14
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:20:14
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:20:14
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:20:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52614 | 2015-09-21 13:20:18
Socket (22) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:20:19
Socket (22) | Shutdown and closed. | 2015-09-21 13:20:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:20:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:20:19
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:20:19
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:20:19
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:20:21
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52614 | 2015-09-21 13:20:23
Socket (23) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:20:24
Socket (23) | Shutdown and closed. | 2015-09-21 13:20:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:20:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:20:24
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:20:24
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:20:24
Rithmic Trading | Port for executable: 52635 | 2015-09-21 13:20:26
Listening socket (128), port 52635 | Closed. | 2015-09-21 13:20:26
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-09-21 13:20:26
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52635 | 2015-09-21 13:20:28
Socket (24) | Connected. | 2015-09-21 13:20:28
Rithmic Trading | Connected to server. | 2015-09-21 13:20:28
Rithmic Trading | Sending logon request message. | 2015-09-21 13:20:28
Rithmic Trading | Starting the connection process to data and trading service. | 2015-09-21 13:20:28
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-09-21 13:20:28
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-09-21 13:20:28
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-09-21 13:20:31
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-09-21 13:20:31
Rithmic Trading | Server Name: DTC Bridge. | 2015-09-21 13:20:31
Rithmic Trading | Server protocol version: 7. Client protocol version: 7. There is a protocol match. | 2015-09-21 13:20:31
Rithmic Trading | Logon error from server | 2015-09-21 13:20:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:20:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:20:31
Socket (24) | Shutdown and closed. | 2015-09-21 13:20:31
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:20:31
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:20:31
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:20:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52635 | 2015-09-21 13:20:35
Socket (26) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:20:36
Socket (26) | Shutdown and closed. | 2015-09-21 13:20:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:20:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:20:36
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:20:36
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:20:36
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:20:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52635 | 2015-09-21 13:20:40
Socket (27) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:20:41
Socket (27) | Shutdown and closed. | 2015-09-21 13:20:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:20:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:20:41
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:20:41
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:20:41
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:20:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52635 | 2015-09-21 13:20:45
Socket (28) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:20:46
Socket (28) | Shutdown and closed. | 2015-09-21 13:20:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:20:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:20:46
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:20:46
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:20:46
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:20:48
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52635 | 2015-09-21 13:20:50
Socket (29) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:20:51
Socket (29) | Shutdown and closed. | 2015-09-21 13:20:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:20:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:20:51
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:20:51
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:20:51
Rithmic Trading | Port for executable: 52660 | 2015-09-21 13:20:53
Listening socket (1036), port 52660 | Closed. | 2015-09-21 13:20:53
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-09-21 13:20:53
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52660 | 2015-09-21 13:20:55
Socket (30) | Connected. | 2015-09-21 13:20:55
Rithmic Trading | Connected to server. | 2015-09-21 13:20:55
Rithmic Trading | Sending logon request message. | 2015-09-21 13:20:55
Rithmic Trading | Starting the connection process to data and trading service. | 2015-09-21 13:20:55
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-09-21 13:20:55
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-09-21 13:20:55
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-09-21 13:20:58
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-09-21 13:20:58
Rithmic Trading | Server Name: DTC Bridge. | 2015-09-21 13:20:58
Rithmic Trading | Server protocol version: 7. Client protocol version: 7. There is a protocol match. | 2015-09-21 13:20:58
Rithmic Trading | Logon error from server | 2015-09-21 13:20:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:20:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:20:58
Socket (30) | Shutdown and closed. | 2015-09-21 13:20:58
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:20:58
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:20:58
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:21:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52660 | 2015-09-21 13:21:02
Socket (31) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:21:03
Socket (31) | Shutdown and closed. | 2015-09-21 13:21:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:21:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:21:03
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:21:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:21:03
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:21:05
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52660 | 2015-09-21 13:21:07
Socket (32) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:21:08
Socket (32) | Shutdown and closed. | 2015-09-21 13:21:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:21:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:21:08
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:21:08
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:21:08
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:21:10
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52660 | 2015-09-21 13:21:12
Socket (33) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:21:13
Socket (33) | Shutdown and closed. | 2015-09-21 13:21:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:21:13
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:21:13
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:21:13
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:21:13
Rithmic Trading | Bridge process is still running. | 2015-09-21 13:21:15
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52660 | 2015-09-21 13:21:17
Error opening image log file in text editor: C:\SierraChart\Images\ImageLog.txt. Windows error code from ShellExecute: Windows error code 2: 系統找不到指定的檔案。 | 2015-09-21 13:21:18 *
Socket (34) | Error received in OnConnect while connecting. Windows error code 10061: 無法連線,因為目標電腦拒絕連線。 | 2015-09-21 13:21:18
Socket (34) | Shutdown and closed. | 2015-09-21 13:21:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:21:18
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:21:18
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:21:18
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:21:18
Rithmic Trading | Port for executable: 52764 | 2015-09-21 13:24:18
Listening socket (548), port 52764 | Closed. | 2015-09-21 13:24:18
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-09-21 13:24:18
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52764 | 2015-09-21 13:24:20
Socket (36) | Connected. | 2015-09-21 13:24:20
Rithmic Trading | Connected to server. | 2015-09-21 13:24:20
Rithmic Trading | Sending logon request message. | 2015-09-21 13:24:20
Rithmic Trading | Starting the connection process to data and trading service. | 2015-09-21 13:24:20
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-09-21 13:24:20
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-09-21 13:24:20
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-09-21 13:24:23
Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-09-21 13:24:23
Rithmic Trading | Server Name: DTC Bridge. | 2015-09-21 13:24:23
Rithmic Trading | Server protocol version: 7. Client protocol version: 7. There is a protocol match. | 2015-09-21 13:24:23
Rithmic Trading | Logon error from server | 2015-09-21 13:24:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-21 13:24:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-21 13:24:23
Socket (36) | Shutdown and closed. | 2015-09-21 13:24:23
Rithmic Trading | Disconnected from the server. | 2015-09-21 13:24:23
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-21 13:24:23
[2015-09-21 14:21:00]
This is the relevant error message:
You are getting a permission denied error from the Rithmic system.
Refer to step 17 here:
Rithmic Trading Platform Service: Setup Instructions
