Date/Time: Mon, 23 Dec 2024 06:12:20 +0000
ACSIL - sc.AreRenkoBars() - true for delta bars
View Count: 929
[2015-09-21 13:20:33]
ejtrader - Posts: 688
SC Team - Apparently this function sc.AreRenkoBars() returns true for delta bars. Is this by design?
I am trying to find out the painted(candlestick) Open/Close Value of the bar. In case if the function sc.AreRenkoBars() true - I am picking up SC_RENKO_OPEN/SC_RENKO_CLOSE for this purpose.
This works fine for flexrenko bars. However in case of delta (also seems to be the case with volume bars) - this function returns true but they don't represent painted open/close.
Are there any alternate options to pick painted open/close values for any chart type?
PS: In case of volumebars - I can use sc.AreVolumeBars() as an alternate option, but no such option for delta bars.
thanks
Date Time Of Last Edit: 2015-09-21 13:49:13
[2015-09-21 16:09:17]
Reviewing this from coding point of view as well.
[2015-09-21 16:47:09]
Ended up being the code issue. This can be Closed.
Not sure why though :)
Just by changing the following code - seems to have fixed the issue - but don't know why it would fix the issue (one of those things - have to check back at a later time during code review).
sg1[i] = sc.BaseData[SC_OPEN][i];
sg2[i] = sc.BaseData[SC_CLOSE][i];
The same code changed to below(no other changes) and it fixed the issue.
sg1[i] = sc.Open[i];
sg2[i] = sc.Close[i];
Date Time Of Last Edit: 2015-09-21 16:47:39
[2015-09-21 18:36:31]
We will look into this.
[2015-09-21 18:42:24]
One problem we found is that sc.AreTimeSpecificBars() would have returned 1 in the case of Delta Volume bars. This has been fixed.
[2015-09-21 19:10:25]
Thank you sc team.
For any one else referencing this thread in the future, the following code seems to detect the painted open/close properly for any type of chart (as of this date). Verified manually.
if(sc.RenkoTicksPerBar)
// SC_RENKO_OPEN & SC_RENKO_CLOSE - These values are likely to represent the candle open/close values
thanks
