Date/Time: Mon, 23 Dec 2024 06:40:50 +0000
Incorrect chart opened using study (IBPT_PRICE_CHANGES_PER_BAR opens IBPT_DAYS_MINS_SECS)
View Count: 770
[2015-09-21 12:55:43] |
wat - Posts: 67 |
Following code (tested on CL-201510-NYMEX) opens intraday chart with 1 second bar length instead of 1 PriceChanges chart. s_ACSOpenChartParameters chartParameters;
chartParameters.ChartDataType = INTRADAY_DATA; chartParameters.Symbol = sc.GetRealTimeSymbol(); chartParameters.IntradayBarPeriodType = IBPT_PRICE_CHANGES_PER_BAR; chartParameters.IntradayBarPeriodLength = 1; chartParameters.DaysToLoad = 3; int chartNumber = sc.OpenChartOrGetChartReference(chartParameters); Can you help me with this bug? I am not sure where the problem might be. Thanks. |
[2015-09-22 04:39:22] |
This will be solved in the next release. This function did not previously support Price Change Bars.
