DTC Protocol Discussion Forum
- DTC Protocol Discussion Forum |
- Search Board |
- Control Panel |
- View My Posts / Threads |
- Direct Messages
Date/Time: Tue, 04 Nov 2025 15:43:05 +0000
OKCoin trading
View Count: 3498
| [2015-09-21 12:23:39] |
| vbmithr - Posts: 204 |
Hi, I am almost done with the implementation of OKCoin trading. This service is, for now, a different DTC server as BitMEX. It handles OKCoin CNY and USD (OKCoin Intl.). Is it possible to add an entry for it in the next version of SC? The server specs are the same as BTC, only the ports are resp. 5569 and 5570 instead of 5567 and 5568 for BitMEX. Thanks. Date Time Of Last Edit: 2015-09-22 06:43:55
| [2015-09-22 05:11:02] |
Yes we can do this. Please allow a couple of days.
| [2015-09-22 06:45:27] |
I'm going to try to pack all my services behind a single DTC endpoint. More futureproof than asking you to add services along the way. I'll keep you up to date with what I need :) |
| [2015-09-24 08:23:55] |
It would be best to be very clear about the IP and port specifications. For OKCoin we are understanding and assuming the following: Market data and trading: 37.187.116.20:5569 Historical price data: 37.187.116.20:5570 |
| [2015-09-24 08:28:22] |
Hi, This is correct. Call this entry "Bitsouk" (-> replace the current bitsouk entry by this one). So for now, there will be BitMEX (Testnet) and Bitsouk in SC, with same IP. Ultimately, there will be only one entry "Bitsouk". |
| [2015-09-24 18:32:33] |
This is now done and is available in the latest prerelease of Sierra Chart.
