Date/Time: Sat, 11 Jan 2025 03:15:17 +0000
No data and I renewed on 9-16
View Count: 728
[2015-09-21 11:42:03] |
narcese - Posts: 58 |
Software version: 1294 | 2015-09-10 11:15:25 Uses Old Spreadsheets | 2015-09-10 11:15:25 Usage end date: 2015-09-20 | 2015-09-10 11:15:25 Enabled for: Advanced Features. | 2015-09-10 11:15:25 Enabled for: Sierra Chart Historical Data Service. | 2015-09-10 11:15:25 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-09-10 11:15:25 Current selected Data/Trading service: SC Forex Data (FXCM) | 2015-09-10 11:15:25 Chart Update Interval: 500 | 2015-09-10 11:15:25 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-09-10 11:15:25 2015-09-10 11:15:25 Local computer time | 2015-09-10 11:15:25 2015-09-10 15:15:25 Local computer time in UTC | 2015-09-10 11:15:25 2015-09-10 11:15:25 Local computer time in SC Time Zone | 2015-09-10 11:15:25 2015-09-10 15:15:25 Server time in UTC | 2015-09-10 11:15:25 Local computer UTC time and Server UTC time difference: 10 seconds. | 2015-09-10 11:15:25 Program path: C:\SierraChart3\ | 2015-09-10 11:15:25 Data Files path: C:\SierraChart3\Data\ | 2015-09-10 11:15:25 OS Version Number: 6.1 | 2015-09-10 11:15:25 Locale Information: C | 2015-09-10 11:15:25 Date Time Of Last Edit: 2015-09-21 14:16:38
[2015-09-21 14:16:21] |
You need to restart Sierra Chart. On the login window enable "Force Login".
