Date/Time: Fri, 18 Oct 2024 06:48:53 +0000
SC api for market data
View Count: 2188
[2015-09-21 10:21:22] |
User12089 - Posts: 350 |
What is the SC API for access to real-time, low level (level 2 tick data / messages) market data e.g. market depth, best price and time and sales - please provide link to the docs about the API functions which can be invoked to obtain these And then the same for Historical data - low level (level 2 tick data / messages) market data e.g. market depth, best price and time and sales |
[2015-09-21 10:33:23] |
Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php The historical data server is not yet developed. But should be in about two months. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-23 11:35:09] |
I meant (especially for the real-time market data part of the question) getting such data from a piece of code running inside SC ie aka SC Study - does such code still need to use the DTC server API or there is ACSIL API for that
[2015-09-23 17:18:16] |
If you want to access the historical and current data, you can use ACSIL: https://www.sierrachart.com/index.php?page=doc/doc_Contents.php#AdvancedCustomStudySystemInterfaceandLanguage You do not need to use the DTC Server for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-23 17:19:11
