Date/Time: Mon, 23 Dec 2024 07:27:26 +0000
Text option within DOM Price levels
View Count: 1089
[2015-09-21 03:45:58] |
bwalks123 - Posts: 122 |
Is there any way to add the ability to input text at a particular price within the trading DOM (Not Chart DOM)? That way you can keep important notes at a particular level.
[2015-09-22 05:06:36] |
This is not supported but we will see if the Text drawing tool can be adapted to work with the Trading DOM.
