Date/Time: Mon, 23 Dec 2024 07:08:03 +0000
Custom indexes
View Count: 1044
[2015-09-20 20:41:29] |
motorola7 - Posts: 19 |
I am doing custom currency indexes (candlesticks) by adding components using the "Sum all charts from list" study. Everything is fine until I try to include the Japanese Yen. All the other currencies chart at values around 1.xxxxx However the Yen charts as 120.xxx, so the index is ruined. I tried dividing the Yen by 100 using the "Study subgraph divide" study and checking "Display as main price graph". This study only acts on a single data point; I selected "Last". It showed a line plot at the desired value of 1.20. But this produced a nonsensical index chart. Is there any way to create a yen candlestick chart with values at 1.20 vs 120 (without spreadsheet)? |
[2015-09-21 12:33:43] |
Problem solved: "It is supported to specify a multiplier for each individual chart. To specify the optional multiplier enter an asterisk (*) after the Chart Number, followed by the multiplier value. Example: 1*1.5, etc." |
[2015-09-21 19:38:26] |
Yes, we were going to recommend to use the multipliers in this case. There are also the Real-time and Historical Price multiplier settings you can use in Chart >> Chart Settings: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#PriceMultiplier Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
