Date/Time: Sun, 08 Sep 2024 01:39:17 +0000
Display of the values of order and position lines on the value scale
View Count: 830
[2015-09-20 19:13:37] |
fireworks11 - Posts: 60 |
When „Align Trade Drawings Text to Right“ is enabled the values of position lines as well as order lines are displayed on the value scale, but when this is not enabled the values on the value scale disappear. Sure, they are now displayed on the left side of the lines, but I very much please you to make the display of the values on the value scale also available when „Align Trade Drawings Text to Right“ is not enabled. This is very important to have the action on the right side visually under control. I assume that it is quite easy for you to implement since you already have it in the „enabled“ version.
[2015-09-28 05:36:16] |
Did you have a chance to look into this?
