Date/Time: Mon, 23 Dec 2024 06:51:02 +0000
"Move To Breakeven for Stop" partly broken now
View Count: 1749
[2015-09-20 18:28:32]
User87197 - Posts: 65
Hi SC. In a [Trade Window for Chart] in the [Targets] tab - the previously functional [BE Level Offset] box can no longer support negative values as it previously could and claims it still can here: http://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html "This level offset can be either a positive or negative number"
I do not have the minus key assigned to another function in Sierra or elsewhere. It doesn't work for the main keyboard OR the numpad. I cannot even paste in a negative value from the clipboard as I can with positive values.
I'm assuming the has been affected by accident.
Many thanks,
[2015-09-20 22:03:29]
We apologize for this. This is a new problem related to the recent changes with the Trade Window to support linking of Trade Windows.
We did try pasting a negative number into the Breakeven Level Offset and it did work. For example, we pasted -5.
Once you also have a nonzero positive number entered, you can enter a - in front of it at that time and it will work as well.
The basic problem is entering a - when the number is a zero, that does not currently work. This will be solved.
Date Time Of Last Edit: 2015-09-21 10:50:17
[2015-09-21 10:49:41]
This is now fixed in the latest revision of the prerelease. Update with Help >> Download Prerelease.
[2015-09-21 11:11:19]
SC Engineering is on it like Sonic, as always. Thanks!
