Date/Time: Mon, 23 Dec 2024 06:55:36 +0000
Continuos contract from another instance of Sierra Chart
View Count: 1082
[2015-09-20 07:55:22] |
User43311 - Posts: 3 |
Is possible load continuous contract data from another instance of Sierra Chart? This don't work for me. See my settings in attached pictures... 1.*.png is settings in first instance and 2.*.png is settings in second instance... In first instance loaded data from years 2008, it's ok, but in second instance load only actual contract month (please see picture 2.4.png, from 2015-07-xx). I want to use data from first instance in second instance. Date Time Of Last Edit: 2015-09-20 08:00:22
[2015-09-20 09:22:06] |
This is not supported. We do not understand why there are so many screenshots here? Please understand that we cannot spend the time to look at all of the screenshots and we did not need to see them. This is explained at step 4 here: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#UsingContinuousFuturesContractCharts The capability you are looking for will be supported in a later release, but probably not until sometime next year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-20 09:22:55
