Date/Time: Mon, 23 Dec 2024 06:29:42 +0000
Changing Study parameters programatically
View Count: 1075
[2015-09-19 16:04:41] |
JordiE - Posts: 38 |
Hi dear Support Board Team, good afternoon ! I would like to know if there is any way to change a Study Parameter by software and/or programatically. I'm referring specifically to a parameter of Zig-Zag Study (Reversal amount for calculation mode 2,3), which I'd need to change according to a variable. As usual, many thanks in advance for your time and help Best regards and have a nice week-end ! Jordi |
[2015-09-20 08:30:01] |
This requires modifying the study itself. The source code is available. Refer to the documentation for this here: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-20 11:09:29] |
Thanks so much, for your quick answer. Have a nice Sunday !! Best regards ! Jordi |
