Date/Time: Mon, 23 Dec 2024 07:01:51 +0000
Pop up information header
View Count: 999
[2015-09-19 14:19:24] |
User738169 - Posts: 2 |
Does Sierra Chart provide a function that could show OHLC information of a specific bar? I have an image example attached. Thanks. |
Screen Shot 2015-09-19 at 20.58.48.png / V - Attached On 2015-09-19 14:17:37 UTC - Size: 29.08 KB - 323 views |
[2015-09-19 21:35:39] |
This can be done with the Chart Values tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-19 22:54:56] |
Sure, I got it. Thanks.
