Date/Time: Mon, 23 Dec 2024 06:40:18 +0000
SC Historical data problem SC_BIDNT, SC_ASKNT
View Count: 750
[2015-09-18 16:53:09] |
User210937 - Posts: 5 |
I was looking at the symbol NQU15 and noticed that SC_BIDNT and SC_ASKNT always have the exact same value. I am using an intraday storage unit of 1 tick. So (SC_ASKNT + SC_BIDNT)=1 not 0 or 2 on any given tick. SC_BIDVOL and SC_ASKVOL seem to work fine... Will you please confirm this and fix it. Thx Date Time Of Last Edit: 2015-09-18 17:03:26
[2015-09-18 17:15:08] |
Did you set sc.MaintainAdditionalChartDataArrays = 1 in your code?
