Date/Time: Mon, 23 Dec 2024 06:20:21 +0000
breakeven level offset won't accept negative numbers
View Count: 1663
[2015-09-18 16:23:09]
jivetrader - Posts: 410
regarding:
https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#MoveBEForStopsLevelOffset
trying to enter a minus sign into the BE Level Offset box produces this error:
Trading Keyboard Shortcuts NOT enabled. Enable with 'Trade >> Trading Keyboard Shortcuts Enabled'. | 2015-09-18 12:19:34 *
my minus key is set to a trading function, however i have turned OFF 'Trading Keyboard Shortcuts Enabled.' do i really have to un-assign the minus key from my shortcuts in order to enter a negative number here?
thanks
[2015-09-18 16:29:00]
Yes you do! There is no other possibility! This will not change!
[2015-09-21 17:15:45]
workaround for this type of issue:
enter the desired negative number in another application, copy & paste from other application into Sierra's entry field
[2015-09-21 18:52:44]
There also was a problem with the entering of a negative number which arose in recent releases which has now been fixed. Update Sierra Chart to the latest revision of the pre-release by selecting Help >> Download Prerelease.
However, this will not solve your problem. We are just mentioning it.
Date Time Of Last Edit: 2015-09-21 18:55:24
