Date/Time: Mon, 23 Dec 2024 06:25:40 +0000
Closing all open trades
View Count: 1121
[2015-09-18 14:19:15] |
User268289 - Posts: 5 |
There's a button to move your stops to Breakeven. Is there a button or shortcut that will close all active trades. For example lets say I'm long on the emini and I see something that tells me the market is going to reverse on me quickly. Is there a way to close my long positions with a button or a shortcut very quickly.
[2015-09-18 15:26:54] |
Did you want to close positions just for one particular symbol or multiple symbols?
[2015-09-18 15:51:48] |
Just one symbol. ES I believe I would simply hit the flatten button? Is that correct?
[2015-09-18 16:49:48] |
Therefore, use the Flatten button on the Trade Window which is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TradeWindowControls Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
