Date/Time: Mon, 23 Dec 2024 06:45:48 +0000
old horizontal alert triggering
View Count: 740
[2015-09-18 14:15:26] |
User170575 - Posts: 221 |
Hi, I have an old horizontal line alert triggering. So when I click in the alert manager and go to "go to chart" it takes me to a chart that does not have the horizontal line. How do I clear the line if I cant see it? Have a nice weekend. CJ |
[2015-09-18 17:48:15] |
It is unlikely that you will be taken to a chart that does not contain the Horizontal Line. Therefore, you probably cannot see the Horizontal Line. Follow the instructions here to locate it and to disable the Alert Condition for it: https://www.sierrachart.com/index.php?page=doc/doc_AlertsManager.html#DisablingAlertSoundsChartDrawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-18 18:20:25
