Date/Time: Mon, 23 Dec 2024 06:32:29 +0000
resetting volume dsplayed on VBP on tradedome - one click?
View Count: 1094
[2015-09-18 12:11:04] |
User60518 - Posts: 106 |
Hi - is there a button (or really quick way) to reset (remove all volme displayed) volume on the tradeDOM? would be handy once you are in a trade to reset the volume - would help to read the order flow Date Time Of Last Edit: 2015-09-18 14:17:30
domvol.JPG / V - Attached On 2015-09-18 12:10:35 UTC - Size: 32.11 KB - 331 views |
[2015-09-18 17:18:27] |
This is not supported. The Volume at Price data is not data which can ever be reset. Inherently this does not make any sense.
[2015-09-19 01:35:01] |
sorry if I was unclear. just wondered if there was a way to discount any data prior to a certain point in time. Say you go long the CL at 45.00 - clearing all the volume information prior to that point in time would then allow you to see only contracts traded at each new price from that point on. Say an extra column on the DOM to display this info rather than clearing the historical volume - kind of a lap timer on a stopwatch as it were? Does that make more sense? Date Time Of Last Edit: 2015-09-19 02:17:29
[2015-09-20 01:12:57] |
What you are interested in is the Current Traded Total Volume column. This is documented at the bottom of the page here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#ChartDOMColumnDescriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-20 01:13:13
