Date/Time: Mon, 23 Dec 2024 06:56:17 +0000
study Time
View Count: 899
[2015-09-18 05:18:11]
User82722 - Posts: 18
http://www.sierrachart.com/image.php?l=1442552129828.png
Why is running study Time - instead of displaying the text 'Night' graph shows something strange. It is noticed that the minute spot grows. How to get rid of it?
The second question - why timeline schedule is interrupted for 7.52 minutes(current day) and then follows the time line the next day 9-20 Su - it's inconvenient especially when to try to determine the time of completion of the figures in the future. How to make that displays a full timeline for the current day?
Date Time Of Last Edit: 2015-09-18 05:25:24
imageStudy_Time.png / V - Attached On 2015-09-18 05:16:14 UTC - Size: 45.54 KB - 327 views
[2015-09-18 07:08:38]
How many Time Line studies do you have on the chart? There should only be one.
The reason you see a jump to Sunday after the last bar on Friday, 09-18, is because that is the next trading day. This is normal.
Otherwise, if the times along the timescale do not look correct, make sure you have the correct time zone setting:
https://www.sierrachart.com/index.php?page=doc/doc_TimeZone.html
[2015-09-18 08:56:18]
Yes ?
Please look desc. study Time Line https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s181
"If you want lines at other times, then add this study multiple times to the chart, and configure each one appropriately."
The problem is likely to display incorrect timescale. After the selected interval to schedule the lineup adds a new time line is redrawn with a time shift and the old meaning of the text(study Time Line) is not erased. I put the standard time in Moscow, and then choose the set of Chicago. The effect was maintained. Here is an example chart :
http://www.sierrachart.com/image.php?l=1442566049882.png
It shows how this looks.
I could put in the settings is not that timescale is not displayed on the full current session (but this proposed scale for the next trading session)?
Thnk:)
[2015-09-18 23:26:12]
You can add the Time Line study to the chart multiple times, but you do not want to set the time for the lines close to each other. Otherwise, you may get overlapping lines.
The answer to the question in the image is to use the Chart Values tool:
https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValues
The timescale in the chart after the last bar, does show the future times.
Date Time Of Last Edit: 2015-09-18 23:26:34
