Date/Time: Mon, 23 Dec 2024 06:21:41 +0000
User Questions
View Count: 912
[2015-09-17 16:26:52]
Sierra Chart - Max - Posts: 5756
1.
Is it possible to add a line from the last price traded box in the x axis that extends into the chart and moves with the price?
2.
Is it possible to enable the chart so that when you click or hover over a candle or bar in a chart you will get the hi/low/close/ and info on indicators in that particular bar?
3.
Is there a way to get the p/l to display in sim on a live connection?
Sierra Chart Support
Date Time Of Last Edit: 2015-09-17 16:27:03
[2015-09-17 16:30:44]
1. Yes. You would need to add the Current Price Line study to do this:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s123
2. Yes. Please refer to the documentation here:
https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ViewingToolandChartData
[2015-09-17 19:10:52]
3. This is not totally clear but if you are referring to the Profit/ Loss of a non-simulated Trade Position when Sierra Chart is in Trade Simulation Mode, the answer is no.
