Date/Time: Mon, 23 Dec 2024 06:45:48 +0000
TT Multi-Broker FIX
View Count: 1641
[2015-09-15 17:52:20]
User181104 - Posts: 4
I have an account with a broker who uses TT.
However, my broker only has a TT Multi-Broker FIX connection and not the TTnet FIX connection.
My broker said that TT told them TT's new Multi-Broker FIX is not compatible with Sierra Chart. Only TTnet FIX is compatible with SC. Is this true? Do you have other people reporting this problem?
[2015-09-15 18:42:35]
If TT says this is true, then you can trust that information is correct.
Sierra Chart does support TT FIX. This is documented here:
https://www.sierrachart.com/index.php?page=doc/TradingTechnologies.php
But according to TT Sierra Chart does not support TT Multi-Broker FIX. This would seem to make sense to us if they say that.
[2015-09-16 06:44:27]
Is Sierra coming up with a solution to support TT's Multi-Broker FIX? thanks
[2015-09-16 07:49:47]
This should not be a problem for us to support. Here are the specifications:
https://www.tradingtechnologies.com/help/fix-adapter-reference/multibroker-orders/
However, we would need to talk with whoever is providing this TT FIX adapter about the details. So who is the broker you are working with?
[2015-09-16 07:53:16]
UOB Bullion & Futures Limited
[2015-09-16 18:54:46]
Can you provide us their website address.
[2015-09-16 18:55:51]
http://www.uobbf.com.sg/
[2015-09-17 22:14:45]
We are going to be contacting them now.
