Date/Time: Fri, 18 Oct 2024 04:39:29 +0000
HEIKEN ASHI
View Count: 895
[2015-09-15 17:48:01] |
User82615 - Posts: 106 |
Could you please send me an example of how to program a sell order to market if last is < open in a heiken ashi chart please, Because I've tried it as in a normal chart and it doesn't work. Thank you very much |
[2015-09-15 18:36:38] |
Do you want to use the Spreadsheet System for Trading study? If so, first start through the test procedure here to see if it works with the example: Spreadsheet System for Trading Test Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-15 18:38:00
