Date/Time: Mon, 25 Nov 2024 12:33:09 +0000
[User Discussion] - Chart Calculator Degrees "understanding"
View Count: 1772
[2013-06-15 01:42:20] |
John W Shelby - Posts: 2 |
I'm having trouble duplicating (using a hand calculator or excel)the degrees answer given with the chart calculator. Using GBP/JPY 1 min or 1 hour chart. Value per point in Ticks: Setting = 1 First I have read your all your documentation and have searched the Old Support board and the New Support Board. But, I'm frustrated by using Rise over Run - I don't get your value. Is there an additional "Factor" that is needed after calculating the Rise/Run formula??? Thank you in advance for your help. Cheers! |
[2013-06-16 00:35:47] |
maxpi - Posts: 181 |
rise/run is the tangent of the angle. You have to solve the trig tangent formula to get the angle.
[2014-02-11 22:16:24] |
Hello, I'm still having trouble matching the answer the calculator tool is giving in degrees. Would you walk me through an example of how I would actually calculate this? Thank you. John |
[2014-02-11 22:24:52] |
http://www.csgnetwork.com/righttricalc.html
