Date/Time: Mon, 23 Dec 2024 04:42:03 +0000
Session Period
View Count: 930
[2015-09-15 13:25:01]
User87794 - Posts: 10
Hi
It appears that the session period check box is not working from the Chart settings. I am able to check the box but it makes no difference to the chart. I have been using it regularly and effectively, however it stopped working at the end of last week.
Is there something I am doing wrong or is there an issue with it?
Rgds
Randell
[2015-09-15 18:24:16]
What is the exact name of the setting you are referring to? There is nothing named "session period".
[2015-09-15 22:47:30]
My apologies
It is the 'Use Evening Session' tab inside the 'Chart Settings'. I was using that to move between the 24hr session to the 8:30/15:00 session. Whether I check the box or not - it makes not difference as it did up until last week. It appears to have stopped working.
I have loaded the latest version etc. turned it on and off etc. makes not difference.
Any suggestions???
[2015-09-16 03:28:10]
We prepared this documentation here for this kind of problem:
https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php#UseEveningSessionDoesNotAffectChartBars
If it does not answer the question, let us know.
