Date/Time: Sat, 23 Nov 2024 03:33:56 +0000
Charts will jump or move during the trading day without being touched - pleased help ! ! !
View Count: 1716
[2013-06-14 21:39:03] |
LadyTrader_ - Posts: 3 |
Many times, the charts will just jump or move. I'm sure it is probably caused by an indicator on the chart adjusting, but I'm just not sure what may be causing it. Any help would be appreciate if you know what it might be |
[2013-06-14 21:44:10] |
Please be more descriptive by what you mean "jump". Do you mean that the chart slides left or right. It is not completely clear.
[2013-06-14 22:11:17] |
The charts will move so that you cannot see price action and then I have to double click in the right side of the chart to get the candles & price action so that it can be seen again.
[2013-06-15 02:17:47] |
Please refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails46.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
