Date/Time: Fri, 18 Oct 2024 04:07:34 +0000
ES etc Futures Charts re when updating to new contract
View Count: 772
[2015-09-14 16:35:51] |
MKL17 - Posts: 35 |
I have my ES futures contracts set to continuous date rule rollover with no pullback. My question relates to draw and time settings on my various charts. When the contract updates my drawings are erased and the time settings seem to revert back to default. I have charts with varying time settings and am wondering if there is a way to keep my drawings as well as the time settings intact when the chart updates. I believe this applies to all futures rather than just ES. Thx.
[2015-09-14 20:03:46] |
Refer to this section here about Session Times to keep them the same when changing the symbol of a chart: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#SettingIntradaySessionTimes Refer to this section here to show Chart Drawings from Drawing Tools, for different symbols: https://www.sierrachart.com/index.php?page=doc/doc_ChangingFuturesContract.html#ChartDrawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
