Date/Time: Sun, 08 Sep 2024 00:35:30 +0000
User Question
View Count: 777
[2015-09-14 16:04:33] |
hi please can you write me if your data from cme and mainly eurex are unfiltered or agregated as give me broker when i subscription for instance eurex,your data are the same as on official page eurex?? in enclosure(can you send me daily data with volume please or write if are same thanks Sierra Chart Support Date Time Of Last Edit: 2015-09-14 20:01:58
Private File |
[2015-09-14 20:17:28] |
The Sierra Chart Exchange Data Feed does not filter CME or EUREX data. However, if you add up the Intraday chart volume it is never going to match the daily volume. This is explained here: https://www.sierrachart.com/index.php?page=doc/helpdetails43.html#h43.7 So you are not really going to be better off using the Sierra Chart Exchange Data Feed. At least not for the CME. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-14 20:17:41
