Date/Time: Sun, 08 Sep 2024 00:41:57 +0000
HEIKEN ASHI
View Count: 882
[2015-09-14 16:03:27] |
User82615 - Posts: 106 |
Hello can anybody tell me yf it is possible to develop a trading system with "Sierra Chart" to be used in a Heiken Ashi graph , because I'm trying to do it and it doesn't work, for example the orders for buy or sell doesn't appear in the Heiken Ashi chart. Thank you very much for your help Date Time Of Last Edit: 2015-09-14 16:03:50
[2015-09-14 18:21:37] |
Yes this is possible.
