Date/Time: Sun, 08 Sep 2024 00:22:56 +0000
Palladium Dec Futures PAZ5
View Count: 830
[2015-09-14 04:27:16] |
User438810 - Posts: 50 |
I'm having trouble getting intraday data before 9/8/2015 for PAZ5. I deleted all data and dload and have it set up to volume rollover back adjusted with 99 days to load. Still not working.
[2015-09-14 20:19:05] |
We are still working on this.
[2015-09-15 05:56:59] |
Update the Symbol Settings as is explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Re-download the data in the chart with Edit >> Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
