Date/Time: Mon, 23 Dec 2024 04:21:51 +0000
programmatically download historical data
View Count: 1723
[2015-09-13 07:27:57]
User102729 - Posts: 3
I want to use Sierra Charts as my data provider along with data I'm already downloading daily from IB (my current broker), so I can cross-validate the data and compare them.
In IB there is an API through which I can easily download historical data programmatically for many stocks and then analyze them offline in my Matlab simulation.
How can I programmatically download historical data for many stocks from SC? Can it be done through IB API?
Thank you
[2015-09-13 22:16:32]
Sometime later this year this can be done using the new DTC Protocol Server:
https://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php
At this time for Daily data you can access this data through the Historical Daily data text files:
https://www.sierrachart.com/index.php?page=doc/doc_TextCSVDataFormat.html
At this time for Intraday data, you can export that:
https://www.sierrachart.com/index.php?page=doc/doc_ImportExport.html
[2015-09-14 18:22:33]
Thank you, I saw these options in the SC program.
What I'm looking for is a programmatic way to download historical data for, say 100 stocks of interest.
Clearly this is very uncomfortable using the menus. Is there an API or dll which I can access and give 100 export commands for 100 different stocks?
Thank you
[2015-09-14 18:45:47]
No there is not.
[2015-09-15 03:43:35]
Is there a way to access SierraCharts data using the IB API?
[2015-09-15 05:34:23]
No. Of course not. This makes no sense.
[2015-09-15 20:21:12]
Cavalry3162 - Posts: 523
could you create a chartbook with 100 charts in it? just open it up EOD and it should dl the data, no?
[2015-09-16 04:34:19]
Yes you can do this.
You can also use the Associated Symbol List and perform a scan to accomplish the same thing:
https://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html#AssociatedSymbolList
