Date/Time: Mon, 23 Dec 2024 02:42:00 +0000
Studies display sequence
View Count: 807
[2015-09-12 22:18:26] |
NumbersBars - Posts: 141 |
Hi Support, When there are multiple studies added into the same chart region, with "Draw Study Underneath Main Price Graph" all unchecked, how do I arrange/determine the display sequence of the studies? For example, Study 1 with drawstyle colorbar candle fill, study 2 with drawstyle Point is there a way to arrange the two studies, so study 2 (POINT) is always displayed on top of study 1? |
[2015-09-13 01:53:19] |
This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#StudyDisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
