Date/Time: Mon, 23 Dec 2024 02:18:48 +0000
connection issue, please assist
View Count: 874
[2015-09-12 17:28:11] |
mattb - Posts: 30 |
Log: Software version: 1294 | 2015-09-12 12:22:18 Uses New Spreadsheets | 2015-09-12 12:22:18 Usage end date: 2016-04-01 | 2015-09-12 12:22:18 Enabled for: Advanced Features. | 2015-09-12 12:22:18 Enabled for: Advanced Features 2. | 2015-09-12 12:22:18 Enabled for: Sierra Chart Historical Data Service. | 2015-09-12 12:22:18 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2015-09-12 12:22:18 Enabled for: CME, CBOT, NYMEX, COMEX exchanges for trading accounts. | 2015-09-12 12:22:18 Received 2 data feed usernames. | 2015-09-12 12:22:18 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-09-12 12:22:18 Current selected Data/Trading service: Rithmic Trading | 2015-09-12 12:22:18 Chart Update Interval: 500 | 2015-09-12 12:22:18 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-09-12 12:22:18 2015-09-12 12:22:18 Local computer time | 2015-09-12 12:22:18 2015-09-12 17:22:18 Local computer time in UTC | 2015-09-12 12:22:18 2015-09-12 12:22:18 Local computer time in SC Time Zone | 2015-09-12 12:22:18 2015-09-12 17:22:18 Server time in UTC | 2015-09-12 12:22:18 Local computer UTC time and Server UTC time difference: 2 seconds. | 2015-09-12 12:22:18 Program path: C:\SierraChart\ | 2015-09-12 12:22:18 Data Files path: C:\SierraChart\Data\ | 2015-09-12 12:22:18 OS Version Number: 6.2 | 2015-09-12 12:22:18 Locale Information: C | 2015-09-12 12:22:18 Checking for new symbol settings for rim | 2015-09-12 12:22:18 Symbol settings are up-to-date for rim | 2015-09-12 12:22:19 Rithmic Trading | Port for executable: 55587 | 2015-09-12 12:22:23 Listening socket (796), port 55587 | Closed. | 2015-09-12 12:22:23 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-09-12 12:22:23 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55587 | 2015-09-12 12:22:25 Socket (4) | Connected. | 2015-09-12 12:22:25 Rithmic Trading | Connected to server. | 2015-09-12 12:22:25 Rithmic Trading | Sending logon request message. | 2015-09-12 12:22:25 Rithmic Trading | Starting the connection process to data and trading service. | 2015-09-12 12:22:25 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-09-12 12:22:25 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-09-12 12:22:25 Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-09-12 12:22:27 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-09-12 12:22:27 Rithmic Trading | Server Name: DTC Bridge. | 2015-09-12 12:22:27 Rithmic Trading | Server protocol version: 7. Client protocol version: 7. There is a protocol match. | 2015-09-12 12:22:27 Rithmic Trading | Logon error from server | 2015-09-12 12:22:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-12 12:22:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-12 12:22:27 Socket (4) | Shutdown and closed. | 2015-09-12 12:22:27 Rithmic Trading | Disconnected from the server. | 2015-09-12 12:22:27 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-12 12:22:27 Rithmic Trading | Bridge process is still running. | 2015-09-12 12:22:29 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55587 | 2015-09-12 12:22:31 Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-12 12:22:32 Socket (5) | Shutdown and closed. | 2015-09-12 12:22:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-12 12:22:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-12 12:22:32 Rithmic Trading | Disconnected from the server. | 2015-09-12 12:22:32 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-12 12:22:32 Rithmic Trading | Bridge process is still running. | 2015-09-12 12:22:34 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55587 | 2015-09-12 12:22:36 Socket (6) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-12 12:22:37 Socket (6) | Shutdown and closed. | 2015-09-12 12:22:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-12 12:22:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-12 12:22:37 Rithmic Trading | Disconnected from the server. | 2015-09-12 12:22:37 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-12 12:22:37 Rithmic Trading | Bridge process is still running. | 2015-09-12 12:22:39 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55587 | 2015-09-12 12:22:41 Socket (7) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-12 12:22:42 Socket (7) | Shutdown and closed. | 2015-09-12 12:22:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-12 12:22:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-12 12:22:42 Rithmic Trading | Disconnected from the server. | 2015-09-12 12:22:42 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-12 12:22:42 Rithmic Trading | Bridge process is still running. | 2015-09-12 12:22:44 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55587 | 2015-09-12 12:22:46 Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-12 12:22:47 Socket (8) | Shutdown and closed. | 2015-09-12 12:22:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-12 12:22:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-12 12:22:47 Rithmic Trading | Disconnected from the server. | 2015-09-12 12:22:47 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-12 12:22:47 Rithmic Trading | Port for executable: 55604 | 2015-09-12 12:22:49 Listening socket (904), port 55604 | Closed. | 2015-09-12 12:22:49 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-09-12 12:22:49 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55604 | 2015-09-12 12:22:51 Socket (9) | Connected. | 2015-09-12 12:22:51 Rithmic Trading | Connected to server. | 2015-09-12 12:22:51 Rithmic Trading | Sending logon request message. | 2015-09-12 12:22:51 Rithmic Trading | Starting the connection process to data and trading service. | 2015-09-12 12:22:51 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-09-12 12:22:51 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-09-12 12:22:51 Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-09-12 12:22:53 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-09-12 12:22:53 Rithmic Trading | Server Name: DTC Bridge. | 2015-09-12 12:22:53 Rithmic Trading | Server protocol version: 7. Client protocol version: 7. There is a protocol match. | 2015-09-12 12:22:53 Rithmic Trading | Logon error from server | 2015-09-12 12:22:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-12 12:22:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-12 12:22:53 Socket (9) | Shutdown and closed. | 2015-09-12 12:22:53 Rithmic Trading | Disconnected from the server. | 2015-09-12 12:22:53 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-12 12:22:53 Rithmic Trading | Bridge process is still running. | 2015-09-12 12:22:55 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55604 | 2015-09-12 12:22:57 Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-12 12:22:58 Socket (10) | Shutdown and closed. | 2015-09-12 12:22:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-12 12:22:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-12 12:22:58 Rithmic Trading | Disconnected from the server. | 2015-09-12 12:22:58 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-12 12:22:58 Rithmic Trading | Bridge process is still running. | 2015-09-12 12:23:00 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55604 | 2015-09-12 12:23:02 Socket (11) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-12 12:23:03 Socket (11) | Shutdown and closed. | 2015-09-12 12:23:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-12 12:23:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-12 12:23:03 Rithmic Trading | Disconnected from the server. | 2015-09-12 12:23:03 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-12 12:23:03 Rithmic Trading | Bridge process is still running. | 2015-09-12 12:23:05 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55604 | 2015-09-12 12:23:07 Socket (12) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-12 12:23:08 Socket (12) | Shutdown and closed. | 2015-09-12 12:23:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-12 12:23:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-12 12:23:08 Rithmic Trading | Disconnected from the server. | 2015-09-12 12:23:08 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-12 12:23:08 Rithmic Trading | Bridge process is still running. | 2015-09-12 12:23:10 Rithmic Trading | Connecting to the server 127.0.0.1. Port 55604 | 2015-09-12 12:23:12 Socket (13) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-09-12 12:23:13 Socket (13) | Shutdown and closed. | 2015-09-12 12:23:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-09-12 12:23:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-09-12 12:23:13 Rithmic Trading | Disconnected from the server. | 2015-09-12 12:23:13 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-09-12 12:23:13 ------------------------------------------------------------ IP: 70.196.5.253 (United States) |
[2015-09-12 18:46:43] |
You are getting a permission denied error from the Rithmic system: Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-09-12 12:22:27 Refer to step 17 here: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
