Date/Time: Mon, 23 Dec 2024 02:28:16 +0000
"clear existing studies on chart"
View Count: 1108
[2015-09-11 16:26:19]
Dennis B. - Posts: 272
How to disable that pop-up when I add a study. Can find no reference doing a search.
[2015-09-11 17:13:12]
When saving a Study Collection there is the option Prompt to Remove Existing Studies. You need to disable this.
It is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_StudyCollections.html#Adding
[2015-09-11 17:24:16]
Sawtooth - Posts: 4141
You can simply rename the file, removing the '-' suffix.
