Date/Time: Sun, 08 Sep 2024 00:39:41 +0000
[User Discussion] - BREAK EVEN ACSIL
View Count: 993
[2015-09-11 15:14:13] |
User406116 - Posts: 2 |
Hello, i would like to know how to calculate the minimum movement in the direction of the trade(since a position has been taken) to break even in ACSIL. Is it the same for different instruments?
Date Time Of Last Edit: 2015-09-11 15:16:25
[2015-09-14 22:33:19] |
Ignoring commissions, the breakeven level will be the entry price for the Trade Position. Otherwise, there really is not such a simple calculation for this.
