Date/Time: Mon, 23 Dec 2024 02:25:15 +0000
changing height of candlesticks
View Count: 1329
[2015-09-11 14:52:09]
User133711 - Posts: 9
I have range bar charts (all set at 4) for YM and NQ. The NQ candlesticks are the height I want but the YM are taller. How can I make the height of the YM candlesticks smaller like the NQ. Thanks.
[2015-09-11 17:35:18]
So you want them to be 4 ticks per bar? For the YM this would be a range of 4.0. Do you want them different than that?
[2015-09-11 18:42:25]
No, I'm sorry I didn't make myself clear. I didn't mean changing the range of the bars, they are all 4. I was referring to the way the 4 range candles appeared on the chart. All the 4 range NQ candles are about 1/2" tall and all of the YM candles are about 3/4" tall. I want to lower the height of the YM candles to about 1/2" tall. Hope I worded it better!
[2015-09-11 23:46:43]
In this case what you need to do is change the scale so that it shows a greater range of prices.
You can use Interactive Scale Range for this:
https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#InteractiveScaling
