Date/Time: Mon, 23 Dec 2024 02:12:08 +0000
Options Chain
View Count: 1888
[2015-09-11 00:52:25]
User760942 - Posts: 120
Hi SC,
Do you offer any special tools to view Options? Such as Options Chains and/or ways to view an Option's delta in realtime?
Or can Options only be viewed on a Chart or DOM like any other security?
Thanks.
[2015-09-11 03:10:51]
These things are not supported by Sierra Chart.
[2015-09-11 04:07:45]
Would it cause extreme latency issues if I built these things via your "Spreadsheet System" and deployed them in my automated trading strategies?
If it would cause extreme latency issues, would the the latency issues be resovled if I instead built them in your C++ solution instead of your spreadsheet solution?
I can build them myself via either method if I put the time in, but before I do, I’d like to be sure they won’t slow down my trading strategies’ latency by more then a fraction of a second
[2015-09-11 17:41:33]
Definitely using ACSIL is going to be more efficient than using Spreadsheets.
Here is the information about ACSIL:
https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html
