Date/Time: Mon, 23 Dec 2024 02:24:26 +0000
two TPO studies on one chart?
View Count: 917
[2015-09-10 20:40:45]
kinghat - Posts: 120
i want to be able to show the evening session with different color settings/options that the regular session. i cant see how to do this with just one TPO study so i was wondering if you can apply two TPO studies and configure them separately.
also is it possible to show the volume profile next to my regular session TPOs but not the evening session TPOs?
i think i found a bug in the line widths for the POC extension lines compared to the VA extension lines.
Date Time Of Last Edit: 2015-09-10 20:45:43
image2015-09-10_15-16-02.png / V - Attached On 2015-09-10 20:42:19 UTC - Size: 72.24 KB - 310 views
[2015-09-11 17:51:22]
The capabilities you are looking for are not supported.
We will make sure that the width can be set for the Point of Control extension line for the TPO Profile Chart study.
[2015-09-11 18:15:22]
ok thanks. im guessing its not possible to run two TPO studys on the same chart?
that issue with the extension lines is that it is set to width of 2 which is the same as the VAH/VAL width, but dont visually look the same width. you can set the POC extension width to 4 which makes it look visually the same as the VAH/VAL extension lines. so the issue is not that cant be changed.
i looked on the forum, but are system wide tabs for all windows on your 'roadmap'?
[2015-09-11 18:25:08]
Yes this is not supported.
What are "system wide tabs"? This is not clear for us.
[2015-09-11 18:29:48]
have tabs on windows/charts that are detached or not part of the main SC window.
