Date/Time: Mon, 23 Dec 2024 03:51:23 +0000
multiple tool values windows
View Count: 958
[2015-09-10 16:29:01] |
freestyler - Posts: 35 |
I would like to have a separate tool values window open for each product that I'm trading (ie. 2 or more tool values windows open at the same time on different monitors). Is this possible?
[2015-09-10 17:40:23] |
No. This is not supported. Are you looking to display values for studies or the main price graph for the last bar in the chart or a specific bar in the chart in these windows? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-10 17:41:05
[2015-09-10 17:42:51] |
I'm looking for the high and low of last bar/specific bar. That's it.
[2015-09-10 19:14:48] |
Have a look at using the Text Display for Study study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s334 You can set it to display these values as text on the chart. You will need to add two instances of the study. One for High and one for Low. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-10 19:28:40] |
Thanks. Looks good so far.
