Date/Time: Sun, 08 Sep 2024 00:38:08 +0000
Available Funds For New Positions in study?
View Count: 876
[2015-09-10 13:31:37] |
wat - Posts: 67 |
Is it possible to get value of "Available Funds For New Positions" from balance tab in study? Thank you. |
[2015-09-11 09:37:17] |
Yes. We can add this. Should be out in about a week.
[2015-09-11 15:28:31] |
ejtrader - Posts: 688 |
SC Team - This is good. Would you please add the ACSIL function as well for this value? Thanks |
[2015-10-23 12:25:46] |
wat - Posts: 67 |
Hello, is there any news about that ? |
[2015-10-23 18:53:27] |
This has been added to ACSIL: sc.TradeServiceAvailableFundsForNewPositions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
