Date/Time: Mon, 23 Dec 2024 03:10:09 +0000
Error simbol
View Count: 798
[2015-09-10 13:18:19] |
User21912 - Posts: 3 |
I established connection, but quotations don't go. Broker of Open E Cry. The screenshot is attached to the message. Thanks
[2015-09-10 17:08:12] |
Sierra Chart - Max - Posts: 5756 |
The symbols that you are using are not correct for Open E Cry. To open a chart with the correct symbol, use File >> Find Symbol as is explained here: https://www.sierrachart.com/index.php?page=doc/doc_GettingStarted.php#Step3 To change the symbol of an existing chart refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html#ChangingChartSymbol Sierra Chart Support Date Time Of Last Edit: 2015-09-10 17:10:02
