Date/Time: Sun, 08 Sep 2024 01:55:53 +0000
Alert for custom study
View Count: 809
[2015-09-10 09:49:51] |
User96105 - Posts: 113 |
I'm using a custom study which prints strength (SG1) and weakness (SG2) indicators by analysing the bar characteristics and volume. I'd like to produce alerts when the signals print. Is this possible without knowledge of how the indicator is working?
[2015-09-10 09:52:41] |
Yes, by looking at the values in the Study Subgraphs. You can check these with the Chart Values tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValues Here is the documentation for Simple Alerts: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-05 04:40:58] |
Thanks, but it seems that this custom study does not actually display any values in the chart values tool other than 1!. The study does have various features including painting bars and displaying triangle up/down. Is there a way I can code the alert to reference what appears on the chart (if bars change to red then alert?). Sorry, I'm sure this is very amateurish... Thanks
[2015-10-05 05:08:34] |
The general answer is no if you cannot determine what the study is doing from the numeric values in the study Subgraphs.
