Date/Time: Mon, 23 Dec 2024 02:01:30 +0000
IB volume chart with dotted gaps
View Count: 830
[2015-09-09 22:45:42] |
freestyler - Posts: 35 |
Hi: I noticed that on a volume chart with data feed from IB, there are often gaps filled with a few dashes (see areas circled in attached). Is there a setting where I can eliminate them (ie. do not draw any dashes, simply draw the next new candle)? http://www.sierrachart.com/image.php?l=1441838613932.png |
[2015-09-09 23:24:28] |
This is explained on this page here: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent: Repeating Bars with Number of Trades or Volume Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-09 23:26:10
[2015-09-09 23:36:49] |
We just updated the section that we linked to, to include a chart image demonstrating this identical problem. So if you reload the page, you will see it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-09 23:37:16
[2015-09-09 23:47:47] |
Thanks. I disabled the Split Data Records option, and everything looks fine now.
