Date/Time: Mon, 23 Dec 2024 01:26:55 +0000
DOM customization
View Count: 917
[2015-09-09 12:48:52]
User231363 - Posts: 31
Is is possible to add custom columns to the DOM using ACSIL?
Is is possible to add custom DOM buttons using ACSIL? (for example, to reset custom column numbers back to zero)
If so, can you point me to the relevant ACSIL functions?
thanks!
[2015-09-09 18:00:30]
1. No.
2. Control Bar/ToolBar buttons can be used by ACSIL and that is documented on this page:
https://www.sierrachart.com/index.php?page=doc/doc_MouseAndMenuInteractionFromACStudy.html
