Date/Time: Fri, 18 Oct 2024 06:06:24 +0000
DOM glitch?
View Count: 1215
[2015-09-08 13:59:04] |
User38993 - Posts: 61 |
Hello I am currently using AMP + Sierrachart (CQG) DOM is displaying numbers at random places. Please take a look at my attachment Is this normal? do I just ignore it? I see red "3" on buy side |
Capture_2015_09_08_22_30_36_81.png / V - Attached On 2015-09-08 13:58:35 UTC - Size: 23.05 KB - 368 views |
[2015-09-08 17:09:35] |
You can see the actual market depth prices and quantities in Chart >> Open Market Depth Window. If you select File >> Disconnect on the main menu and File >> Connect to Data Feed does the market depth become correct? If so, really there is not anything we can do about this. It just has to do with the data from the server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-28 13:30:00] |
Currently Dom numbers do not appear for Nasdaq 100 mini, but it appears from crude oil. Any clue?
[2015-09-28 13:36:06] |
take a look at screenshot
Capture_2015_09_28_22_35_03_521.png / V - Attached On 2015-09-28 13:35:55 UTC - Size: 19.91 KB - 347 views |
[2015-09-28 13:46:52] |
I just updated to the latest version as well. no help
[2015-09-28 14:14:31] |
Latest version update seems to solve the problem. Thanks!
[2015-09-28 17:09:41] |
It looks like you have not set the Trade DOM columns to contain the Bid and Ask Sizes. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-05 11:48:54] |
I am actually still having this problem. Market depth does not display for NQ (F.US.ENQZ15)
[2015-10-05 16:40:15] |
Select Chart >> Open Market Depth Window. Do you see the market depth displayed for 10 levels? Move that Market Depth window over the Trade DOM at least partially and select Chart >> Upload Chart with Overlays. Press Yes and paste the link here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
