Date/Time: Mon, 23 Dec 2024 06:30:35 +0000
Adjust chart drawings after rollover
View Count: 1426
[2015-09-08 08:31:04] |
natanibz - Posts: 135 |
Hello, is there a way to adjust at the same time, for example, all YM chart drawings in all charts and in all contracts in the charts ? Also only all chart drawings of all contracts in one chart. Because if i select more than one contract ( tools > manage chart drawings window ) then i cant use the Adjust button. Thanks |
[2015-09-08 08:45:43] |
No. This is not supported. Also only all chart drawings of all contracts in one chart. Because if i select more than one contract ( tools > manage chart drawings window ) then i cant use the Adjust button. We will check on this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-19 16:56:33] |
Al SC Developer - Posts: 434 |
In the next version, you will be able to select drawings with different symbols when adjusting via the Manage Chart Drawings Window. All selected drawings will be adjusted by the same amount.
