Date/Time: Mon, 23 Dec 2024 00:13:32 +0000
Implied Spreads
View Count: 808
[2015-09-07 13:19:44] |
Trade Nice - Posts: 75 |
1) Once you have finished implementing implied spreads via the 'Sierra Chart Real-Time and Historical Exchange Data Feed', will there be historic data from when implied spreads started being offered by the CME, or just historic data from the time of SC's first implementation? 2) Even though the implied spread symbol will need to be in the correct format for the SC data feed, I assume it will be possible to use SC with the Data/Service set for example to Interactive Brokers, and with 'Allow support for Sierra Chart data feeds' enabled? 3) It will though mean that although other IB symbols will be remapped to the required symbols for the SC data feed, it will mean that it wont be possible to enter orders from a chart for implied symbols since they would be the wrong format for Interactive Brokers? Date Time Of Last Edit: 2015-09-07 15:43:32
[2015-09-07 19:35:41] |
1. just historic data from the time of SC's first implementation
Yes.2. I assume it will be possible to use SC with the Data/Service set for example to Interactive Brokers, and with 'Allow support for Sierra Chart data feeds' enabled?
Yes.3. it wont be possible to enter orders from a chart for implied symbols since they would be the wrong format for Interactive Brokers?
Yes this is correct.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-07 19:35:51
