Date/Time: Mon, 23 Dec 2024 00:59:44 +0000
chart fonts and colors
View Count: 1286
[2015-09-07 00:09:32]
Dennis B. - Posts: 272
How do I change the fonts on the right side of the chart also how to change color of header on chart
[2015-09-07 06:27:34]
Fonts and Colors are set through the Graphics Settings window which is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html
Not sure what you mean by "header", but if that is a window title bar, that is controlled through your operating system.
[2015-09-07 15:04:49]
OK, found the font thingy..thx. What I have here is SC on a new pc and somethings are a little weird. At the top of the chart I used to just have the net-change amount, now there is a long string of numbers that I have no idea what they are, How to disable or get rid of please. On my old pc the trade menu was grayed out, it is enabled now. How to disable ? What you need in your table of contents is a how to disable stuff page.
[2015-09-07 17:01:23]
Another item, how to change the fonts on the horizontal and vertical lines. So small they'
re unreadable. Were fine on old pc, running ver.1282 on both.
[2015-09-07 19:41:22]
Ok, got rid of those numbers on top of chart. still can't change fonts on horz./vert. lines.
[2015-09-08 01:21:06]
Sounds like you are referring to the Chart Header in the Region Data Line. Refer to the documentation here:
https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#RegionDataLine
It has never been possible to disable the Trade menu.
To change the Chart Drawing Font, refer to:
https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartDrawingText
Date Time Of Last Edit: 2015-09-08 01:21:58
