Date/Time: Mon, 23 Dec 2024 00:32:56 +0000
SC Historical Data
View Count: 863
[2015-09-06 12:50:29] |
Trade Nice - Posts: 75 |
After a summer break, struggling a little with reminding myself of how your data services work. My interest is CME Nymex CL Crude Oil futures and I use TWS. 1) Is the historical CL futures data from 'Sierra Chart Historical Data' the same as the historical CL futures data from 'Sierra Chart Real Time and Historical Data Feed'? 2) If using 'Sierra Chart Real Time and Historical Data Feed' and connected to the TWS, does that mean that Sierra Chart then only ever gets data from 'Sierra Chart Real Time and Historical Data Feed' and the TWS is then just a trading platform (Sierra Chart gets no data from the TWS)? 3) Is the point of using the 'Sierra Chart Real Time and Historical Data Feed' rather than the direct TWS feed that... a)its then possible to get the historical data without the downloading pain of getting it from TWS? b)the real time data is more accurate as it does not have the TWS data filtering? Thank you Date Time Of Last Edit: 2015-09-06 14:33:10
[2015-09-06 23:02:12] |
1. Yes. 2. For the exchanges you have activated, yes. Here are additional details: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration 3. Yes. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
