Date/Time: Mon, 23 Dec 2024 00:35:31 +0000
TPO not working.
View Count: 1229
[2015-09-05 22:58:32] |
User31660 - Posts: 20 |
(Message Log removed)
Date Time Of Last Edit: 2015-09-05 23:53:06
[2015-09-05 23:53:17] |
Be more descriptive about the problem. We do not need to see the Message Log.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-05 23:53:40
[2015-09-06 01:49:49] |
Dear Sirs, I am trying to get TPO Profile Chart and I just put it on my GU 30 min chart and nothing came up. I wonder if the SC can't process the request or maybe I don't have the right package but nothing comes up but a blank screen |
[2015-09-06 02:16:41] |
You need Sierra Chart Service Package 5 to use the TPO Profile Chart study. To change your Sierra Chart service package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on "Change Service Package".
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your usage time is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-06 02:17:29
